Cswa
#1 Posted : Monday, March 15, 2021 11:52:02 PM(UTC)
Cswa
When I try to set up a Lower Third by using the Add-Input>>Title/XAML Option, I can choose a Template, but there is NO PREVIEW of the Template. When I close the Template with my input wording, I do not see a view of that customized Lower-Third. I only see a black screen. When I click on the Lower-Third, nothing happens except that the input locks up. No Lower-Third ever appears.
Am I missing something. I have watched Tim's explanation of how to set up a Lower-Third several times, but what he shows doesn't work for me.
#2 Posted : Tuesday, March 16, 2021 12:02:54 AM(UTC)
what video did you watch ? you must have missed something . did you click OK to select the title as a new input ?
fyi Title/xaml does work
Cswa
#3 Posted : Tuesday, March 16, 2021 1:03:37 AM(UTC)
Cswa
I fully believe that it works for others, but it "no workie" for me. There are not many tutorials for Lower-Thirds. I just notice that what happens when others set up the Lower-Third doesn't happen for me. Are there any options or preferences that could be set wrong? Everything else in vMix seems to work for me...so far.
Yes, I did click "OK" but nothing happens after that. On the tutorials, I see that there is a preview of the Lower-Third, but none for me. When the dialog box closes out, all I see is a black screen.
#4 Posted : Tuesday, March 16, 2021 1:11:37 AM(UTC)
what version ?
what license ?
Graphics card used ?
which title ?
Cswa
#5 Posted : Tuesday, March 16, 2021 1:31:28 AM(UTC)
Cswa
Here are my stats:
vMix Version: 24.0.0.51 x64 (Just did the update an hour ago)
Edition: HD
Beast: MSI-GL73 9SDK (Laptop)
Windows: 10 HP
Graphics: NVIDIA GeForce GTX 1660 Ti
Title: None of them work; I remember before one or two of them worked, now none.
Hold on...The non-GT Lower-Thirds DO WORK. There is a clue.
#6 Posted : Tuesday, March 16, 2021 1:35:47 AM(UTC)
Maybe the update did reset the graphics card used ? see performance
Cswa
#7 Posted : Tuesday, March 16, 2021 1:41:05 AM(UTC)
Cswa
I am new to this vMix Forum and don't exactly know where things should go. Which one of these post would be better to delete, the one under General-Discussion or this other one under GT?
SOLVED:
Looking at Performance right now in vMix>>Settings. It shows my Graphics Card: the [NVIDIA GeForce GTX 1660 Ti]. Any other setting that could be wrong?
WELL..That was my issue. VMix didn't like my Graphics Card for some reason. I switched the Graphics Adapter over to [Intel(R) UHD Graphics 630], and everything works now. VMix doesn't like the [NVIDIA GeForce GTX 1660 Ti]!! Hope that there are no OTHER complications from making this switch somewhere else in the digital mix.
WAIT: There was MORE Still!! I saw this URL from vMix:
https://www.vmix.com/kno...n-nvidia-optimus-laptops
Now I have set up NVIDIA using the NVIDIA control panel to work with vMix and now I CAN use my [NVIDIA GeForce GTX 1660 Ti]. I had to follow the steps as explained in the vMix post.
Wow! So vMix was OK, but NVIDIA needs a special invitation to work with vMix.
Thanks doggy for helping me fix this!!
Maybe someone else will benefit from this run-around.
