Data Source Short Cut Google Sheets
Hey All,
I'm really struggling to get the DataSourceNextRow shortcut working from a google sheet. No matter what combination I try it doesn't seem to respond.
Data Source = Google Sheets Table = Ticker Tape Column = Text
I feel like the input should be Google Sheets,Ticker Tape but no response. Think I've exhausted pretty much every combo but probably making a silly mistake somewhere.
no need to specify a column, as you are changing the row index ( next row)
also make sure the vMix window is active and not the datasource one before using the shortcut
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Just a thought: I always use names without spaces for my data sources, just in case. Do spaces get URL encoded when sent over the wire ? Do I need to wrap things in quotes ? I don't know, I just use underscores and avoid any potential problems...
Originally Posted by: doggy  no need to specify a column, as you are changing the row index ( next row)
also make sure the vMix window is active and not the datasource one before using the shortcut That was my thinking so Code:Google Sheets,Ticker Tape
should work. But, it doesn't seem to. I've tried removing the space and making it but that seems unresponsive too. Thinking it might be easier just to manage it all in google sheets but feel like this should work.
