Joined: 3/23/2020(UTC) Posts: 139  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
I notice if the aspect ratio of an input doesn't change when using the merge transition between two inputs, the border will scale dynamically with the input. If the aspect ratio is different, the border will disappear, then reappear once the input has reached the new size. Is this the intended behavior. It would be pretty awesome if the border would scale dynamically all the time. greg
