peixe
#1 Posted : Thursday, March 11, 2021 5:02:38 AM(UTC)
peixe
Brazil
Was thanked: 11 time(s) in 3 post(s)
Hi
I am working on a test that uses something similar to a "SQUERGE" effect:
For the graphics bottom and side bar I created a GT title that has a logo on top that fades in and out.
If I use that animated title as a layer on an input and unclick the "automatically play with transistion" option all transitions IN stop working (nothing happen if you have that input on preview and click any of the buttons)
The cut button on the input also doesn´t work but the quick play one does.
The transition buttons do work to transition OUT of it (i.e. if that input is on air after hitting quick play, all the transitions buttons will transition out of it into your preview)
I understnad that if the title has an animation and you disable the automatically play with transition is a mixed instruction and probably an uncommon and confusing setting but it took me a while to understand what was going on to figure ut the issue.
Not sure if this is a bug or an unexpeccted behaviour but it would be more natural that the transition does happen but the animation doesn´t execute instead of the transition button not responding at all.
