sepr
#1 Posted : Monday, February 22, 2021 8:56:20 PM(UTC)
sepr
Hello
We're RTBF Belgian Broadcast channel.
We'd like to know if it's possible to route more than master LR on NDi output.
For example:
Ouput 1 through NDI
Audio 1: Mix PGM L
Audio 2: Mix PGM R
Audio 3: BusA L (international sound)
Audio 4: BusA R (international sound)
Thank you very much for your replies !
#2 Posted : Sunday, March 7, 2021 6:59:35 PM(UTC)
Salut la Belgique !
quick answer: yes
long answer : it's all explained in the manual
https://www.vmix.com/help23/Audio3.html
with detailed info on audio i/o settings, even an audio matrix !
Also check this : https://www.vmix.com/hel...orkDeviceInterface1.html
Similar Topics
NDI Audio output sample rate different from vMix master sample rate (NDI)
Belarus Maestro232 8/7/2023 1:07:39 AM(UTC)
Help. Enabling NDI audio outputs, kills existing buses (General Discussion)
by Indrestudios 6/2/2020 1:01:18 AM(UTC)
