Hi all, I am having an issue ...I want to set a VU meter for my output, but am not able to get it to work....it works on all inputs, but not on the final out....I need this, so I can have it large, and seprate from the sliders .....what am I doing wrong, or is this not available
Joined: 8/5/2017(UTC) Posts: 582  Location: Manitoba Thanks: 121 times Was thanked: 322 time(s) in 184 post(s)
Hi Joeboe,
I know you use the Panel Builder a lot. Is this regarding the Panel Builder app ? If so, You can simply use the command "Audio > SetMasterVolume" in a VU. Don't enter anything in the "Input" field.
Richard
 1 user thanked raugert for this useful post.
Thank you...it works, but I always did that and it never used to work,...maybe I was doing something else and not realize it.....well, I am happy .....another thing, can you add level marks, even if they are not very accurate, so as to make the VU meters look more realistic...When used by itself, it looks so plain....or, make it so I can add a PNG file on it with my own level marks, as is done in the icon buttons....
Thanks Joeboe
