zonuna
#1 Posted : Saturday, March 6, 2021 4:46:47 PM(UTC)
zonuna
India
I am planing to build a simple multicamera setup using PTZ cameras with DECKLINK DUO2 and VMIX, I have seen some reviews mentioning that although Decklink Duo2 have an option for 1080p50/60 and 1080i50/60 But cannot be activated and that only 1080p30 can be used.
I just want to confirm this before investing, and and if this is true please guide me for good 4 HD SDI input capture card.
Andrew
#2 Posted : Saturday, March 6, 2021 10:10:52 PM(UTC)
Andrew
Was thanked: 8 time(s) in 4 post(s)
I have the original Decklink Duo (not the "2") and it supports 1080p60.
Babbit
#3 Posted : Sunday, March 7, 2021 12:55:47 AM(UTC)
Babbit
Was thanked: 26 time(s) in 20 post(s)
I've been using the Decklink Duo 2 almost exclusively at 1080p/59.94 with no issues.
I think the closest I've come to full I/O usage is 2 inputs and 1 output simultaneously. And it ran like a champ.
xaver
#4 Posted : Sunday, March 7, 2021 1:42:53 AM(UTC)
xaver
we use 1080p50 without issues
only after about 48 hours the video freeze
restart vMix or reset input and it works again
this problem also is with 720 (all framerates)
zonuna
#5 Posted : Monday, March 8, 2021 5:05:08 PM(UTC)
zonuna
India
Thanks for your kind replay, very helpful, I will to response when everything is setup
