stream is mirrored in Microsoft Teams
Joined: 2/10/2015(UTC) Posts: 34   Location: La Paz, MX Thanks: 9 times
 when I am transmitting to Microsoft Teams through NDI Virtual Input, the image is flipped How can i fix it?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
That's fine, it's only in the preview, the actual output is not reversed.
People are used to seeing themselves in the mirror, that's why it's reversed.
There's no option to turn it off though.
Originally Posted by: Vince Beck  That's fine, it's only in the preview, the actual output is not reversed.
There's no option to turn it off though. It is not in the preview, the process was actually flipped and I don't see an option to "turn it off"
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
the preview that team provide to you is always mirrored. While in the meeting it is not. If you would write down your name on a white paper and hold it in from of you and use the normal camera , than you will see that it is mirrored.
If you move to the left the mirrored image will go in the same direction to make sure that you are in frame.
If you doubt. Use the meet now option and start a recording.
