VB Scripting: CHR(#) not recognized
Joined: 10/29/2019(UTC) Posts: 105  Location: Syracuse Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
Okay, I need to programmatically enclose a string in quotation marks. When I'm writing vb.Net apps this is usually by appending Chr(34) to each end. But for some odd reason, vMix's script interpreter has no idea what Chr(34) is, nor Strings.Chr(34).
Ideas or alternate methods?
Can you show what you mean (code or intention)
Line 13 below. Passing arguments to a cmd.exe... Code:
'Configure webcams
Console.WriteLine(Microsoft.VisualBasic.Strings.Format(DateTime.Now(),"HH:mm:ss") & " | Configuring webcams...")
ExtProcessParams = New Diagnostics.ProcessStartInfo
ExtProcessParams.FileName = "cmd.exe"
ExtProcessParams.CreateNoWindow = true
ExtProcessParams.UseShellExecute = false
ExtProcessParams.RedirectStandardError = true
ExtProcessParams.RedirectStandardOutput = true
ExtProcessParams.Arguments = "/c " & Chr(34) & "C:\Program Files (x86)\CamSet\ConfigureWebcams.cmd" & Chr(34)
ExtProcess = Diagnostics.Process.Start(ExtProcessParams)
ExtProcess.WaitForExit()
ExtProcessResult = ExtProcess.StandardOutput.ReadToEnd()
ExtProcessError = ExtProcess.StandardError.ReadToEnd()
If Not ExtProcess.ExitCode = 0 Then
Console.WriteLine(Microsoft.VisualBasic.Strings.Format(DateTime.Now(),"HH:mm:ss") & " | Configuring webcams failed.")
Console.WriteLine(Microsoft.VisualBasic.Strings.Format(DateTime.Now(),"HH:mm:ss") & " | " & ExtProcessResult)
Console.WriteLine(Microsoft.VisualBasic.Strings.Format(DateTime.Now(),"HH:mm:ss") & " | " & ExtProcessError)
End If
ExtProcessResult = ""
ExtProcessError = ""
ExtProcessParams = Nothing
ExtProcess = Nothing
Google tells me Code:'In VB.NET you must use 2 quotes: "John Said ""Hi"""
& """" & "c:\Program .....
Well I'll be damned - all the years I've been writing vb.net stuff, and the only way I knew to do this was appending character codes. I had no idea you could escape quotes with....more quotes in .Net.
I guess using Chr(34) is a habit I picked up in VB6 and it worked in .Net too, so I never changed.
I searched earlier too, but I searched "CHR(34) alternative" then ran out of time before digging deeper.
Thanks doggy.
