Web Browser Colud Not Be Found
I have not used web interface before. But when I try to open it I get the error message. What could be the problem?
offliner63 wrote:I have not used web interface before. But when I try to open it I get the error message. What could be the problem? Hi, Did you enable the Web under:- Settings --> Web --> Check Button (Enable)?
Damn2Good4U wrote:offliner63 wrote:I have not used web interface before. But when I try to open it I get the error message. What could be the problem? Hi, Did you enable the Web under:- Settings --> Web --> Check Button (Enable)?  when I click on the IP I'll get the message
Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
try opening a new browser window and insert the IP manually...
