kaduramos
#1 Posted : Thursday, March 4, 2021 4:45:15 AM(UTC)
kaduramos
Brazil
Was thanked: 10 time(s) in 5 post(s)
Hi
I have a BlackMagic Ultrastudio 4k mini
And I want to send two different diferents inputs for it.
Could be SDI And HDMI or the two SDI.
But when i turn on the external gives me this error message
Select Video format is not supported by this device bmdModeHD1080p2997
Acess denied (exceçao de hresult :0x0070005
(E_ACESSDENIED))
"StartStopExternal
Selected Video Format is not supported by this device: bmdModeHD1080p2997
Acesso negado. (Exceção de HRESULT: 0x80070005 (E_ACCESSDENIED))"
So there is way to use the two external at same time? BM SCREEN.jpg (69kb) downloaded 0 time(s). External 1.jpg (109kb) downloaded 1 time(s). External 2.jpg (109kb) downloaded 0 time(s). error message.jpg (190kb) downloaded 1 time(s).
xaver
#2 Posted : Thursday, March 4, 2021 7:02:00 AM(UTC)
xaver
AFAIK there is only one independent output, You can connect to SDI and HDMI Output at the same time, but you get the same Video
and you only can have one Input at the same time (select it in Desktop Video Setup) of vMix "Port"
Is it Working if you setup only one External in vMix?
zenvideo
#3 Posted : Thursday, March 4, 2021 7:04:32 AM(UTC)
zenvideo
You have been a member since:: 5/13/2014(UTC)
Kaduramos - Have you checked out the exact capabilities of the Ultrastudio 4K Mini? Most BMD I/O devices are only single channel (even if they have two physical output connectors) and I don't know of any where you can send different signals to the SDI & HDMI outputs - they're usually just alternative connections for the same video output signal, as in my Decklink and MiniMonitor PCIe cards.
powercat
#4 Posted : Saturday, August 14, 2021 5:23:29 AM(UTC)
powercat
Taiwan, Province Of China
Hi kaduramos
I also want to buy UltraStudio 4K Mini,I have some questions,Can it input and output signals at the same time?(Simultaneously input 1 camera sdi to vmix and extemal output vmix PGM or fill&cut)
If anyone can answer, thank you
