Preview Input not fading or going live
Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
I have had an issue that is not very common but has happened a few times.
We run vMix for our church services. We have an multiview input that we combine a video camera shot with a desktop capture when we are viewing scripture. There have been a few times when we have this input loaded in the preview window and when we hit "Fade" or another transition, nothing happens. We hit it multiple times and nothing happens. Sometimes we can click to a different input and back to the original input and it will fade. However there have been times where this would not work. We are using vMix for our side screens for live video, so this glitch is not good for our services. Has anyone else had anything like this happen?
-Seth
thecloudmediagroup wrote:I have had an issue that is not very common but has happened a few times.
-Seth I have also experienced same... I actually thought it was my PC... Now that you mentioned it, it seems to me like a bug
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Can you confirm if you are running 12.0.0.120?
Thanks,
Martin vMix
12.0.0.98 I have the "Check for updates automatically" checked but it doesn't show an update when I start. I will update to this and see if I have the issue. Now I believe we have had this issue in past versions as well. I'm not sure if this makes a difference but here is the layout of the multiview. Base Layer: Motion Background MP4 (Looping) Layer 2: Live Camera Feed Layer 3: Desktop Capture Here is a link to the vMix File if you want it. https://www.dropbox.com/...z718ot8n4/BugPreset.vmix
There was a possibly related fixed between .98 and .120 so it may solve it. One thing to try once .120 is installed is to fade back and forth between that input and see how many times (if any) the fade doesn't work.
