vMix Call
Swiss National Broadcaster
Joined: 8/18/2013(UTC) Posts: 44 Location: Switzerland
Thanks: 1 times Was thanked: 5 time(s) in 4 post(s)
The Swiss National Broadcaster is using vMixcall on a regular base! Instead of sending reporters for interviews they use vmixcall.  Screenshot 2021-03-02 22.05.08.png (1,673kb) downloaded 14 time(s).https://www.srf.ch/play/...2-4574-926d-db62621dcf2fat 2:15....could be geoblocked
I suspect this is not vmixcall, but SRT. Recognizable by the yellow control lamp above. The recorder control lamp also lights up.
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Yes, this is the journalist vMixcall place. (record only, not live) The system records 2 files, the caller with his audio only and the local camera with full audio mix. The yellow buton is SOLO (Audio Guest only), the red one is record. The system is controlled with a Streamdeck Mini. There are separate vMix control rooms for live events.
 1 user thanked Peter1000 for this useful post.
vMix Call
