Remote Cell Phone Camera as a Source
Joined: 2/5/2021(UTC) Posts: 39  Location: Fort Worth Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: mavik  That is way too complicated and adds a lot of latency. Download Larix Broadcaster App on Android or iOS and send an SRT stream directly into vMix. This is much more efficient and direct. You need to NAT/PAT the ports from your router to your vMix in order to get this running. Thanks, Mavik! I am actually on that path already. I get concerned at times when I see the feed freeze on stutter. I take it, it's all dependent on cell signal, but it has performed better than going RTMP into NGINX. Any settings you recommend to deal with freezing and stuttering? I know you can up the latency and turn down the bitrate (affecting quality). Is it worth setting a variable framerate or variable bitrate?
Joined: 9/9/2017(UTC) Posts: 36  Location: Jeffry_Ghost Thanks: 10 times Was thanked: 2 time(s) in 2 post(s)
Couple years ago we used WoWza for it, it's not that cheap but it got app for Android and iOS and for 10 minute entrée was delay around 0,5-1,2 second
Originally Posted by: ocrtalk  Originally Posted by: mavik  That is way too complicated and adds a lot of latency. Download Larix Broadcaster App on Android or iOS and send an SRT stream directly into vMix. This is much more efficient and direct. You need to NAT/PAT the ports from your router to your vMix in order to get this running. Thanks, Mavik! I am actually on that path already. I get concerned at times when I see the feed freeze on stutter. I take it, it's all dependent on cell signal, but it has performed better than going RTMP into NGINX. Any settings you recommend to deal with freezing and stuttering? I know you can up the latency and turn down the bitrate (affecting quality). Is it worth setting a variable framerate or variable bitrate? Increase the latency setting (believe the rule of thumb was like 4 times the slowest ping or so ) Once had to go to 4 seconds , sat (receiver) was part of the chain but had descend bandwidth on phone
