RonanP
#1 Posted : Tuesday, March 2, 2021 11:12:19 PM(UTC)
RonanP
Bonjour,
I use a Motu fireware UltraliteMK3 for the sound interface and:
VMIX software is set to 48khz
Motu interface is set to 48khz ( as I can read and see on the device and in the control panel )
but I get "44100 Hz 32 Bit Float 2 Channels" set in the input audio format????
And the sound is pitched down !!!???
So how can I can set this ?
Ronan
in Paris France
Merci!
vmix audio format.png (18kb) downloaded 2 time(s).
Jeffry_Ghost
#2 Posted : Wednesday, March 3, 2021 8:29:25 PM(UTC)
Jeffry_Ghost
Czech Republic
+1
Vince Beck
#3 Posted : Thursday, March 4, 2021 4:24:54 AM(UTC)
Vince Beck
I don't own a Motu but for now, you could always change the VMix Master sample rate to 44100: https://www.vmix.com/hel...tm?AdvancedSettings.html
RonanP
#4 Posted : Thursday, March 4, 2021 7:28:29 AM(UTC)
RonanP
Bonsoir,
@ Vince: it was not working....
IN fact I got this answer from VMix
"Hi Ronan,
By default, vMix is set to 48000Hz @ 32Bit Floating point and masters at 16Bit PCM:
Audio Formats in vMix | vMix
I am not familiar with the MOTU UltraLite Mk3 device, but it should have similar options to the SHURE MVi as mentioned in this article:
Shure MVi low pitch / audio speed up issue | vMix
As such, you will need to make changes within the device's own settings as it is not possible to select or choose this from within vMix.
I hope that helps.
Kind Regards,
Greg Akeson
support@vmix.com"
https://www.vmix.com/kno...ch--audio-speed-up-issue
Thanks to Greg, that's the point and as I come from the Apple Word, I'm not used with Windows "multiple" control panel....
The problem is not in the MOTU control panel but in the WIndows Sound advanced settings. And I have a french version of Win10 so the translation of the tabs in the sound panel are "weird" : the setting of the default sampling audio rate is called " Statistiques avancées" "Advanced Statistics" ??? ( thanks to google, reverso ...)
Hope this help!
