Highlight speaker only when he speaks
Hey, I was wondering if there's any way to automatically enable a border around someone but only when they are speaking. Once they are done, the border will automatically be disabled. The idea is that if there are multiple people on a vmix call who don't have a camera, the audience is able to tell who's speaking thanks to the border.
use trigger OnAudioMeterDB to overlay or layer a border frame
I tried that. So the issue I'm having with that is that it needs to hit the minimum 18DB, I want it to be there for even lower than that since one of my guests is way louder than the other. So I need something that turns on if there's any activity on the mic and not restricted to the 18DB, is there something like that?
Originally Posted by: zypher4  I tried that. So the issue I'm having with that is that it needs to hit the minimum 18DB, I want it to be there for even lower than that since one of my guests is way louder than the other. So I need something that turns on if there's any activity on the mic and not restricted to the 18DB, is there something like that? Part of your production should be as such that all your audio is at a "same" level for it to be pleasing to listen too If the above function doesn't cut it for you one can always check the levels from the API XML using scripting IMO though bad idea to automate that, imagine when multiple will open their mouth , would responding to their audio being active(allowed) be better ?
