USB Indictor Light - For Cheap
Please find the below python script to run a blynclight as a status indictor. Much cheaper (and nicer looking) than some of the other equipment available. Uses vMix TCP connection.
# -*- coding: utf-8 -*- """ Created on Sat Feb 27 22:35:03 2021
@author: jabal """
import socket import time import blynclight sock=socket.socket(socket.AF_INET, socket.SOCK_STREAM)
server_address = ('localhost', 8099)
try: b=blynclight.BlyncLight.get_light() b.color=(0,0,200) light=True except: light=False print('no light')
while 1: time.sleep(.5) try: sock.connect(server_address) except: print('vmix not open') vmix=0 while vmix==0: try: time.sleep(.5) test=sock.sendall(b'ACTS Streaming\r\n') data = sock.recv(100) if str(data)[-6]=='1': if light: b.on=True print('streaming') else: if light: b.on=False print('not streaming') except: vmix=1
also - note that you can change the color of the light, make it blinking, etc.
