removing leading zeros in string variable
I'm trying to remove leading zeros from a string variable.
3 instead of 003
I can't seem to understand how to get from a string functions I can find searching for VB.Net string functions like
Mid(String, Int32)
into the format needed in vmix script like
activeinputname.Substring(V_position,2)
I believe it has something to do with methods but those far I haven't figured it out. Is there a resource available which shows the methods available in vmix scripting. They seem similar to Javascript but not exactly
One idea I thought of was to convert string to integer and then back to string to strip leading zeros, but I couldn't find correct syntax for that.
Thanks in advance for any assistance.
Jim
in VB cstr(val("003")) will return "3"
I'm sorry but I don't understand how to script with that command.
test = cstr(val("003"))
doesn't work with error message "val" is not declared. This is the same issue I have with other string manipulation commands.
What would be the syntax in vmix scripting to set string variable test to the string variable value without leading zeros
