Paul_WCP
#1 Posted : Monday, February 8, 2021 6:38:33 AM(UTC)
Paul_WCP
Germany
this would be really helpful for bigger setups. We usually mix the callers ourselves with Yamaha Mixers and use DVS for the Outputs.
Recently I needed to send the guests translated audio feeds so I couldn't use the internal mix minus. I had to use two machines to not run out of Buses. If I were able to chose audio inputs directly to send back to guests instead of buses that would make things much easier.
BasilChessman
#2 Posted : Friday, February 26, 2021 4:56:24 AM(UTC)
BasilChessman
+1
tom@24bit.io
#3 Posted : Saturday, February 27, 2021 4:50:19 PM(UTC)
tom@24bit.io
Along with direct outputs ( https://forums.vmix.com/.../t20441-Audio-Direct-Out ) this would make external mixing much smoother.
+1
