Aaron Rebbeck
#1 Posted : Wednesday, February 24, 2021 9:43:16 PM(UTC)
Aaron Rebbeck
We are doing a series of Gaming events which are requried to have a 4.5 minute delay  before output, which we are using replay for.  We have a Primary and backup system with identical specs running the same project file .  We are experiencing a "Slip in time" on our back up and not on a primary machine.  Over a 5 hour event the instant replay is adding an additional 10 minutes delay from the start of the event.
We are not using the instant replay function for any other use, it's essentially set and forget.
The Instant replay is receiving a feed from Mix 2 and being output on Output 2 to a Decklink @ 1080p 59.94
Any ideas on how to solve this problem ?
Rinsky
#2 Posted : Wednesday, February 24, 2021 10:52:30 PM(UTC)
Rinsky
Use the Video Delay input instead of the Instant Replay Input for this stuff
thanks 1 user thanked Rinsky for this useful post.
Aaron Rebbeck on 2/25/2021(UTC)
Aaron Rebbeck
#3 Posted : Thursday, February 25, 2021 5:21:39 AM(UTC)
Aaron Rebbeck
Thanks for this ..any reasoning for that ..always saw the video delay as a way of adding few frames for sync, not to drop in minutes to a broadcast. Does the audio delay and the video delay stay in sync with each other if there set to the same delay?
ask
#4 Posted : Thursday, February 25, 2021 8:18:07 AM(UTC)
ask
Use the Video Delay input ....... Does the audio delay and the video delay stay in sync with each other if there set to the same delay?
Yes it will stay in sync. However the video delay input is limited to 120 sec. It is essentially a large buffer. https://www.vmix.com/hel...ndex.htm?VideoDelay.html
Aaron Rebbeck
#5 Posted : Thursday, February 25, 2021 8:40:01 AM(UTC)
Aaron Rebbeck
Thanks ill look into it but as were tryin to do 4.5 minutes id rather try to get the back up working using the Replay function as the Primary works fin using that method
