jvphobic
#1 Posted : Sunday, February 21, 2021 11:19:46 AM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
Is there a setting to change that when I hit the "-20" button while IN a current replay it doesn't automatically jump to that position and interrupt my current replay happening? Using Vmix24. I can't seem to get it to work. Maybe a setting I am missing?
Radiotvpat1982
#2 Posted : Monday, February 22, 2021 12:56:50 AM(UTC)
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
That does seem like a bug if it's doing more than just creating a new file.
You are saying it creates the new file and then autoplays it in place of the currently running replay?
xaver
#3 Posted : Monday, February 22, 2021 1:50:02 AM(UTC)
xaver
If you are live in Recording the -20 makes a new event with a new ID
But it will not jump to that position. If you playing a IR then you also can press "-20" to create a new event
the position of the IR always stays where it is (and for me this must be because otherwise you can't play and mark at the same time)
jvphobic
#4 Posted : Monday, February 22, 2021 2:22:31 AM(UTC)
jvphobic
For me when I am playing an IR in Vmix24 and I hit the -20 button it immediately jumps to that replay. I currently have it set to A/B but it doesn't seem to matter. But, if I hit mark in & then mark out, that does NOT happen. Only when I hit the pre-set buttons or use the function: Function=ReplayMarkInOut&Value=15.
So, I don't know if that is a bug or the way it is supposed to happen. If anyone else is using Vmix24 and can verify that is how it works for them as well, I would appreciate it.
#5 Posted : Monday, February 22, 2021 2:32:50 AM(UTC)
nope, doesn't happen
