Feature Requests
AutoSave a Temp Preset every 15 minutes
Joined: 2/19/2017(UTC) Posts: 31   Location: United States Thanks: 23 times Was thanked: 2 time(s) in 1 post(s)
It would be great if there was some form of Autosave like in various other business applications so that in the event that you forget to save every 10 minutes manually, if there is an unexpected system or application failure there is a temp setup file saved to prevent losing hours of work.
This could be a user setting to opt on / off.
If there was an unexpected shut down, user would be presented with an option to restore last unsaved setup.
Thanks!
Paul
Joined: 12/27/2012(UTC) Posts: 5,497  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
Help files : Periodically, vMix automatically saves the current Preset to a separate file. Click Last to load this Preset
Feature Requests
