KRTW
#1 Posted : Thursday, February 18, 2021 5:55:11 AM(UTC)
KRTW
Canada
Trying to get this working, but its not. Unit shows up in the list as an activator, its enabled....but if I try clicking the Channel Mappings - no device shows up. Can I use this thing.....Its all I got..
ask
#2 Posted : Thursday, February 18, 2021 6:36:51 AM(UTC)
ask
Was thanked: 199 time(s) in 181 post(s)
Are you trying this with vMix or Central Control? There is no channel mapping option in vMix. This model is not a supported controller with vMix.https://www.vmix.com/software/supported-hardware.aspx#controllers
KRTW
#3 Posted : Thursday, February 18, 2021 9:39:34 PM(UTC)
KRTW
Canada
Its just a midi device and should work - from your link, here's what vmix says:Controllers can be used to perform common functions in vMix such as executing shortcuts and switching inputs etc. The below list contains only controllers we have tested with vMix and therefore is only a sample of controllers you could use with vMix.
Thanks.
KRTW
#4 Posted : Friday, February 19, 2021 4:01:04 AM(UTC)
KRTW
Canada
Thanks.
It doesn't work. Bought an APC mini. Get it tonight.
