Joined: 2/16/2021(UTC) Posts: 4  Location: Pretoria Thanks: 1 times
Hi, After input 26, my inputs become greyed out. The input is created but the content it should display is grayed out. Clicking on cut, cuts to a black frame, the audio of the input seems to be working fine but the video aspect of it does nothing, it doesn't give a preview nor does it actually play the video in the program monitor after I clicked on it to play. This problem has happen after updating VMIX since the last two updates. I'm currently running V23.0.0.68. I've attached an image of the problem. (Input 25 and 26). My system is a i7 8700K, GTX 1080, 32 GB of RAM, Windows 10 running VMIX Pro.  VMIX ISSUE.PNG (17kb) downloaded 2 time(s).
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Overloaded GPU ?
Use List if you need to handle many video files
Thank you for your reply, the GPU mem is running at 22%, so I doubt that that is the problem. It does the same with anything I add past input 26.
