AssignInput & 'Sub-Input' Numbering
Hi All,
I was going to put in a couple of feature requests since I've not seen them here or in the docs. Just wanted to be sure I'm not missing them if they're already there.
1) AddInput - is there a parameter or alternative to replace an input source (like clicking the "Change" button in the GUI), so that the settings are retained and things stay in the proper order? Add, Move, Delete, and other commands in sequence are a bit clunky and don't accomplish everything that a ReplaceInput command could do in a one-step command.
2) Category Numbering. If you build a base profile to make future show setup more efficient (no input renaming, shortcut changes, etc.), assigning commands to input number instead of the specific input seems the way to go. That's how I've done it for some input types, but that significantly limits any kind of re-ordering. What if everything had a running input number (as they do now), but each category had a unique input reference as well? Like A1, A2, B1, B2, etc.
Then one could use that identifier for inputs in categories that may be quite fluid from show to show, without affecting commands that apply to other categories.
