SergeyK.
#1 Posted : Monday, February 15, 2021 11:50:10 PM(UTC)
SergeyK.
Russian Federation
Good day! I cannot find a solution to this problem: During the live broadcast of the competition, it is necessary to display the jury's marks on the screen at the same time as the commentator calls them. There are 6 jury members, estimates from 1 to 5. If I use the title editor, I do not have time to enter the data. I would very much like if pressing the number key would enter the first point, the second press of the number key would enter the second point, and so on. I'm new to scripting, so I ask for help, tell me the script writing algorithm. But if the masters write such a script, I will be very grateful!
#2 Posted : Tuesday, February 16, 2021 12:55:12 AM(UTC)
Sure
How fast are they announcing the individual scores that you can not keep up ?
why not use shortcuts for the scores itself (1-5) ? but you still will have to select one of the 6 positions though. If automatically to the next what if you made an error and want to go back ?
Henny
#3 Posted : Tuesday, February 16, 2021 1:05:09 AM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
Could the Commentator or someone else enter the numbers into a Google sheet before they are announced then you can just have some shortcuts that Show/Hide each Feild.
#4 Posted : Tuesday, February 16, 2021 1:07:40 AM(UTC)
Yes
Part of covering such events is a cooperation with the organization for such things regarding presenting results etc
SergeyK.
#5 Posted : Wednesday, February 17, 2021 4:04:32 PM(UTC)
SergeyK.
Russian Federation
Sure
Hello doggy! The scores are shown like this: The performance ends and all members of the jury raise the scoreboards. The commentator pronounces them one after another. 1.5 - 2 seconds between grades. I manage to show one assessment using shortcuts. But how do you move to the next position? or do you need to make 5 * 6 = 30 shortcuts? I tried to use Date Sourse, but in reality it turns out to show all grades immediately after the end of their pronunciation. I'm almost ready to stop there, but I really want to solve this interesting problem - the commentator calls the assessment and it immediately appears on the screen)
SergeyK.
#6 Posted : Wednesday, February 17, 2021 4:06:43 PM(UTC)
SergeyK.
Russian Federation
But unfortunately this is not the case
Babbit
#7 Posted : Wednesday, February 17, 2021 5:16:38 PM(UTC)
Babbit
Was thanked: 26 time(s) in 20 post(s)
I really don't think scripting is the way to go.
Consider making your own panel where you can quickly click the scores for each judge. I've used vMix Panel Builder, which is in the 3rd party forum. The example below only took me 5 minutes to make with no scripting or coding:
Sample
You can even put the program on a different system as long as it can communicate with your vMix system over network. It gives you the chance to delegate the job to another position.
You'll probably want to add more functions to the panel, like clearing the scores. Also not leaving out the sixth judge like I did is probably a good idea. You can also take advantage of the OnDataChange event if you're using GT title if you want to animate each score as it comes in.
The same thing can be accomplished with a MIDI controller with a lot of buttons and shortcuts, but obviously you're buying more things at that point.
dmwkr
#8 Posted : Wednesday, February 17, 2021 5:38:52 PM(UTC)
dmwkr
How I tried to use Date Sourse, but in reality it turns out to show all grades immediately after the end of their pronunciation. I'm almost ready to stop there, but I really want to solve this interesting problem - the commentator calls the assessment and it immediately appears on the screen)
Yeah, but you seem to have enough time to enter the numbers into the data source by yourself. So hiding/unhiding the fields with pages in a GT title is a good solution.
SergeyK.
#9 Posted : Wednesday, February 17, 2021 6:04:29 PM(UTC)
SergeyK.
Russian Federation
Sample
Many thanks! You gave me a good idea! I will definitely do it
