NDI
NDI app iPhone
Joined: 11/6/2017(UTC) Posts: 6 Location: The Netherlands
What is the best (free) NDI app for iPhone?
Thank you, Roy
There is Larix broadcaster that can send SRT into vmix. I would recommend that route.
I'm not sure if Mavik works for Larix or something, but this is specifically an NDI forum and all he does is suggest SRT to people lol.
The NDI-HX cam in my experience is the most reliable, but you may also want to check out OBS Camera as it has much more manual control over the image.
Originally Posted by: aaron804  I'm not sure if Mavik works for Larix or something, but this is specifically an NDI forum and all he does is suggest SRT to people lol.
The NDI-HX cam in my experience is the most reliable, but you may also want to check out OBS Camera as it has much more manual control over the image. Hi, which of the many OBS camera apps do you sugest? I have NDI HX Camera but I can not set the resolution and framerate manually. Don't need FullHD If the stream is just in 720, but need a high framerate. Thanks Henrik
Be assured that I don't work for larix. And even if, Lrix is free. So what benefit would it bring me. On a mobile device I doubt NDI is the best way to go. I would prefer SRT. But it's totally up to you.
NDI
NDI app iPhone
