Script to export GT Title using DataSource
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
This is my first attempt at scripting in vMix but, with the help of examples from the 'Scripting for Dummies' thread and this other post (https://forums.vmix.com/posts/t23962-Movie-Title--name), I've managed to build a functioning script which loops through a CSV DataSource and exports a PNG image of my lower-third with each row of data. So far so good except that, in all the examples I've found so far, loops use a hard-coded limit. I don't see anything in the API results - is there a way for a script to retrieve the number of entries in a DataSource ? Looking at the VBscript docs (https://docs.microsoft.com/en-us/dotnet/visual-basic/programming-guide/language-features/control-flow/loop-structures), it seems like it should be possible to use an API command in a While loop. But, since API commands return a status code (e.g. 200) rather than a boolean, I can't find a way to get that working. There are no doubt some other optimisations - avoiding defining variables inside a loop ? Padding the file numbers to 2 or 3 digits ? - so I'm open to suggestions for improvements. Thanks Code:' Export Titles as images.
Dim title_input_no as integer = 29
Dim datasource_row_count as integer = 33
Dim snapshot_file_basename as string = "synthe_"
Dim snapshot_file_extension as string = ".png"
Dim snapshot_filename as string
dim xml_data as new system.xml.xmldocument
dim title_text as string
Dim title_text_word_last as String
Dim index as integer = 0
' Send Title to Preview.
'API.Function("PreviewInput",Input:=title_input_no)
'API.Function("DataSourceSelectRow",Value:="Excel/CSV,Sheet1,0")
' Loop through Data Source rows.
While index <= datasource_row_count
API.Function("DataSourceSelectRow",Value:="Excel/CSV,Sheet1," & index)
sleep(500)
dim xml as string = API.XML()
xml_data.loadxml(xml)
title_text = (xml_data.SelectSingleNode("//inputs//input[" & title_input_no & "]//text[1]").InnerText)
Dim words as String() = title_text.Split()
title_text_word_last = words(words.getUpperBound(0))
if title_text_word_last = "" then
title_text_word_last = "title"
End If
snapshot_filename = snapshot_file_basename & index & "_" & title_text_word_last & snapshot_file_extension
API.Function("SnapshotInput",Input:=title_input_no,Value:=snapshot_filename)
sleep(1000)
index += 1
End While
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
AFAIK there is no vMix integrated option to retrieve a data source row count
but you can loop through it and count them by comparing data. If data is same as previous you reached end of list
In the case of a a CSV/text file one can do a line count of the file itself directly (google "vb.net count rows in csv file")
Similar can be done with a xml file
Hi Doggy,
Thanks for those suggestions. I'm trying to keep things as simple as possible so that the script could be used by other people, and I think querying the CSV file directly might complicate things. I was hoping there would be the equivalent of array.length or list.size() I could grab.
I did wonder about comparing rows to detect the end (or comparing to the first row, in case looping is set to On). I have one client who likes to add all the names to the CSV sequentially so, if a speaker appears in more than one session, their name is repeated - so it's not impossible that there would be edge-cases where comparing rows would bail out before reaching the end of the CSV file, but I guess it would work 99% of the time.
Originally Posted by: matkeane  I'm trying to keep things as simple as possible so that the script could be used by other people, and I think querying the CSV file directly might complicate things. I was hoping there would be the equivalent of array.length or list.size() I could grab. so one line would complicate things ? <g> Code:Dim RowCount = File.ReadAllLines("D:\File.csv").Length
Haha, no, that will simplify my script... but will involve explaining to other users which line in the script to modify and how to find the file path of the CSV file referenced by the lower-third! Having said that, I think I saw some examples of opening a file dialog from a script, so that users can pick the file themselves... but that's a bit advanced for my needs at the moment. Thank you for that code - I will add it to my script and it's probably less error-prone than comparing text rows. ... and, now I have allow for header rows after getting the row count from the file. And fix the 'while' loop using '<' instead of '<='. Updated version below : Code:' Export Titles as images.
Dim datasource_header_rows as integer = 1
Dim datasource_file_path as string = "D:\absolute\path\to\my\datasource.csv"
Dim datasource_row_count = File.ReadAllLines(datasource_file_path).Length
datasource_row_count -= datasource_header_rows
console.writeline("Found "& datasource_row_count &" rows in file: " & datasource_file_path)
While index < datasource_row_count
sleep(500)
End If
sleep(1000)
index += 1
End While
