Pleung
#1 Posted : Friday, February 12, 2021 1:14:26 AM(UTC)
Pleung
Canada
I have created a google sheet datasource to use on two custom GT title overlays and created two shortcuts to control Datasource next row and previous row. All works great.
What I need to know is since I only need the datasource to update at start what value should I put in the field update every _ milliseconds. I was hoping if I put in 0 as the value, ie like a duration on an overlay, the datasource will only check once, but I am not sure if that is correct.
Thanks for any guidance.
Pat
#2 Posted : Friday, February 12, 2021 1:43:15 AM(UTC)
V24 has a pause button for that now,
Otherwise not updating the source itself will not "update" the datasource and as extra put a very high number in for time interval
Pleung
#3 Posted : Friday, February 12, 2021 3:07:24 AM(UTC)
Pleung
Canada
Thanks for the quick reply, we have the current version 23 installed.
What I am trying to do is stop the datasource from checking for updates. As I don’t have version 24 and don’t know how to get it, what is the maximum I can set the update every _ milliseconds?
Thanks Pat
#4 Posted : Friday, February 12, 2021 3:28:56 AM(UTC)
Thanks Pat
vMix 24 is currently still in Beta and can be downloaded from the first topic in the general tab
As i said if you are not updating the Source itself it would not matter how much you check for an update as then it will always be the same data
Have no idea what the max update value is
