Joined: 10/12/2020(UTC) Posts: 20  Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Is it possible to open multiple Input Settings windows simultaneously? I need to be able to invoke different overlays on a Virtual Camera input and, invoke different overlays on a Multi-view Input, between transitions! The ability to open only one Input Settings window at a time is a real pain!
Joined: 4/23/2017(UTC) Posts: 1,450  Location: Germany Thanks: 3 times Was thanked: 192 time(s) in 172 post(s)
Not to my knowledge. But you can use the overlays as a central point that effects the outputs.
Originally Posted by: mavik  Not to my knowledge. But you can use the overlays as a central point that effects the outputs. I have a PowerPoint in 'Multi-view' with multiple overlays on it, then I have a 'Virtual Input' of the main camera with multiple overlays on it..., I'm switching the overlays all the time so, I can't be calling up each individual Input Settings window one at a time. I need them side by side because I'll change an overlay in Preview, transition to Output all the while pushing 2-4 faders on the mixing board! I need to do this fluidly and constantly throughout the whole service. Also, another question: Why can transition delays, on the T-bar, only be set to a maximum of 9999 milliseconds?  000509.png (71kb) downloaded 0 time(s).
