Delpit Christine
#1 Posted : Tuesday, February 9, 2021 2:23:11 AM(UTC)
Delpit Christine
Hello there,
I have difficulties with the 2 functions "set output2" & "set external output2".
To avoid multiple shortcuts on the same button of my streamdeck, I'd like to call a script with a single shortcut .
My aim is to send the input "2" to the external2 (and to route the audio to the bus A at the same time -> this point is working)
My script is :
Function=SetOutputExternal2&Value=Input&Input=2
Function=SetOutput2&Value=Input&Input=2
It doesnt't work: the source routed to external2 doesn't change (although it is working with a shortcut)
Does someone can help me/has encountered the same experience?
Thanks you :)
#2 Posted : Tuesday, February 9, 2021 3:36:40 AM(UTC)
Try Closing the settings window and opening it again to check if changed . There seems to be a little issue in updating when still in the settings windows and switching between the script and the outputs to check
#3 Posted : Thursday, February 18, 2021 4:07:19 AM(UTC)
Originally Posted by: gefiltafish Go to Quoted Post
Also got a similar problem with scripting, cannot execute that Output2 (or ExternalOutput2) to show output on another PC, but start/stop External command works like a charm.
Tried doggy solution but it didn't work, any updates?
How would an external output have the ability to show up on another pc (compatible output devices) unless it's NDI or SRT .....?
Code:
Function=SetOutput2&Value=Input&Input=10
' where 10 is an input number
gefiltafish on 2/18/2021(UTC)
gefiltafish
#4 Posted : Thursday, February 18, 2021 4:12:30 AM(UTC)
gefiltafish
Code:
Thanks, but found a solution (my wording was wrong, I apologize). Thanks anyway :)
Delpit Christine
#5 Posted : Friday, March 5, 2021 8:22:47 PM(UTC)
Delpit Christine
I tried several things: close the settings windows/write the script in a .text file and copy-paste ...
I don't remember the order of the actions but it finally worked
Thank for your answers!
RSB
#6 Posted : Tuesday, September 28, 2021 9:11:17 PM(UTC)
RSB
Did anyone figure this out?
web function: http://127.0.0.1:8088/api/?function=SetOutput3&Value=Input&Input=10
works fine.
But scripting: Function=SetOutput3&Value=Input&Input=10
doesn't work.
#7 Posted : Wednesday, September 29, 2021 12:11:51 AM(UTC)
works fine.
doesn't work.
Is that the only line of code in your script ?
https://forums.vmix.com/...ng-for-Dummies#post70833
