GT
Automatic Transition IN (OUT) when data counter is greater than zero (less than zero)
Joined: 2/2/2021(UTC) Posts: 14  Location: Moscow Region Thanks: 5 times
Dear developers, I would like to implement the following function in the GT Designer. When the counter is greater than zero, the title automatically made "Transition IN", and when the counter is zero or empty - the title automatically made "Transition OUT". I apologize for my English. I hope this video will help you understand what I'm asking you to implement.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Use scripting to test and trigger GT title options or bake it in with code in a legacy XAML title
Originally Posted by: doggy  Use scripting to test and trigger GT title options or bake it in with code in a legacy XAML title Please tell me where I can view information on about scripting and trigger for GT title???
Please search this forum, there is a lot of information regarding scripting (not just for GT titles) like the "scripting for dummies" topic and more You can find there all you need for this particular request In this particular case you need to check for the value of your clock in the title and perform an action on it
Please search this forum, there is a lot of information regarding scripting (not just for GT titles) like the "scripting for dummies" topic and more You can find there all you need for this particular request In this particular case you need to check for the value of your clock in the title and perform an action on it Doggy i was not able to find the necessary information on the problem. ((( Can you help me?
Originally Posted by: Vyacheslav  Doggy i was not able to find the necessary information on the problem. ((( Can you help me?
https://forums.vmix.com/...86-Scripting-for-Dummiesread clock from title if clock is zero do what you want else if don't know how hire me else loop (till clock is zero)
GT
