Josemite
#1 Posted : Saturday, February 6, 2021 7:29:19 PM(UTC)
Josemite
How do you 'Preview' the audio before transitioning it to the 'Output'? I assumed I'd be able to run that audio out to a separate bus, but I can't figure it out.
I'm cycling in & out a lot of video clips and really finding that I need to be able to preview the audio. Right now I'm go through the motions of pretending I'm changing the source, so I can copy the location and bring it up outside of vMix... but this is time consuming & I can't hear what the sound level in vMix will be.
#2 Posted : Saturday, February 6, 2021 7:38:55 PM(UTC)
"Solo" of the input in preview ?
See helpfiles:
Select the output to send the Headphones audio mix to.
This mix is the same as Master Output except when Solo is enabled on an input.
When Solo is enabled on an input only that input will be heard.
Josemite on 2/8/2021(UTC)
Josemite
#3 Posted : Monday, February 8, 2021 10:54:12 AM(UTC)
Josemite
See helpfiles:
Oh crap, I misunderstood 'solo' to mean it would send only that audio to the Output.
Thank you!
Playing now with how to make a shortcut to solo whatever is in the preview window.
