ocrtalk
#1 Posted : Friday, February 5, 2021 6:08:09 AM(UTC)
ocrtalk
I'm looking to livestream outdoor trail races. Cameras will be phones over cell signal. Any recommendations on which protocols I should use when using an app like Larix Broadcaster?
I've tried setting up an RTMP server and got very unreliable results. Today I started playing with RTSP and SRT
RTSP I could not get to connect unless on the same network.
SRT I had a great test with, good connectivity, good quality, but I can't figure out how to connect more than one phone using this method.
Any suggestions would be greatly appreciated!
mavik
#2 Posted : Friday, February 5, 2021 6:31:05 AM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
I would go for SRT.
For multiple connections you need a different port
Cam 1 = Port 4001
Cam 2 = Port 4002
You need to create inputs for each port as well.
ocrtalk on 2/5/2021(UTC)
ocrtalk
#3 Posted : Friday, February 5, 2021 7:06:22 AM(UTC)
ocrtalk
Thank you! Seems as though I was getting confused on how to add multiple because it only list one in the recents list. But I'm able to create multiple using different ports. Thanks so much!
ocrtalk
#4 Posted : Saturday, February 6, 2021 1:41:53 AM(UTC)
ocrtalk
I've got one more question about SRT. I've seen videos where people say you can use the same port with different Stream IDs to have multiple cameras. I can't seem to add a second SRT input if the port is the same but the StreamID is different. Is this possible in VMix?
Guest (4)
Similar Topics
First off, G'day all! (looking for guidance) (General Discussion)
by Jup 10/8/2013 5:14:53 AM(UTC)
