NDI
Remove audio input on NDI source?
Howdy...
Is there anyway to remove the audio input on an NDI Source, similar to how you can 'uncheck' audio when adding a normal camera source?
I know I can turn off and minimize these in the audio mixer, but I'd rather not have them show up at all, for the sake of simplicity and reducing errors with novice operators, etc...
Thanks!
Ben
Joined: 2/5/2021(UTC) Posts: 38  Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
+1 for the feature !! because when working with many audio/video inputs there's a lot to turn off - one more pain point in the checklist everytime.
you can sort of fudge this, by disabling the follow (double arrow icon in audio mixer) for that specific input in the audio mixer, then for the input settings/audio settings turn off/uncheck "visible in mixer"
Joined: 4/23/2017(UTC) Posts: 1,472  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
I haven't tested it but theoretically you should be able to manipulate the audio with the birddog NDI/Dante bridge. If you replace the audio with a silent dante source you should get silence. I don't know if you have to assign the audio at all. So maybe you can leave the dante source blank and might remove it that way.
NDI
