I know this problem has been discussed more than one time but this couldn't be a CPU or Network problem, why?
Just because this log below, is a stream to Microsoft Azure, this has been created from a streaming platform for my final customer. I'm a video technician and my job is to stream to this rtmp link. After many attempts to streaming with v-mix without success, i've tried using OBS, and it works, but i can't use that beacause i have setted audio bus and Vmix Call for live translation. So at this point i thought v-mix was the problem, but just to be sure, i've created a free personal account to Azure and created a new live rtmp to do my test. Now streaming through vmix toward my rtmp works with no problem, but if i use their link (streaming platform) it gives me the problem in the log below.
Here, my situation:
Streaming setting are the same to both rtmp links (in slot 2 i've checked "Use Stream 1 Quality")
Dell G5, I7 9850H, 16GB DDR4, RTX 2060, NVme 500GB, Windows 10. The tests are done in the same moment with the same lan (non right at the same time otherwise the CPU would be overloaded). Even if it seems to work from log at the beginning, checking on their prewiev link, i cannot see nothing with vmix, with OBS no problem.
Can someone help me?
ffmpeg started on 2021-02-01 at 11:35:42
Report written to "C:\ProgramData\vMix\streaming\streaming1 20210201-113542.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 1250k -g:v 120 -preset:v veryfast -profile:v main -level:v 3.1 -b:v 2500k -maxrate:v 2500k -minrate:v 2500k -codec:a libfaac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/23.0.0.67)" -f flv rtmp://test-xxxxx-rtmp-1-xxxxxams-euwe.channel.media.azure.net:1935/live/97c5846bd56d4660bfbcabfc54811375/123456
ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc
libavutil 55. 2.100 / 55. 2.100
libavcodec 57. 3.100 / 57. 3.100
libavformat 57. 2.100 / 57. 2.100
libavdevice 57. 0.100 / 57. 0.100
libavfilter 6. 9.100 / 6. 9.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 256212.931000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1920x1080, 60 tbr, 10000k tbn, 60 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 0461d560] TCP Buffer has been set to 6571008 bytes
[libx264 @ 0461a9a0] MB rate (216000) > level limit (108000)
[libx264 @ 0461a9a0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 0461a9a0] profile Main, level 3.1
[libx264 @ 0461a9a0] 264 - core 144 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 -
http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0x111 me=hex subme=2 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=4 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=120 keyint_min=12 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=cbr mbtree=1 bitrate=2500 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=2500 vbv_bufsize=1250 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00
Output #0, flv, to 'rtmp://test-xxxxx-rtmp-1-xxxxxams-euwe.channel.media.azure.net:1935/live/97c5846bd56d4660bfbcabfc54811375/123456':
Metadata:
encoder : Lavf57.2.100
Stream #0:0: Video: h264 (libx264) ([7][0][0][0] / 0x0007), yuv420p, 1280x720, q=-1--1, 2500 kb/s, 60 fps, 1k tbn, 60 tbc
Metadata:
encoder : Lavc57.3.100 libx264
Stream #0:1: Audio: aac (libfaac) ([10][0][0][0] / 0x000A), 48000 Hz, stereo, s16, 128 kb/s
Metadata:
encoder : Lavc57.3.100 libfaac
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (libfaac))
Press [q] to stop, [?] for help
frame= 59 fps=0.0 q=6.0 size= 5kB time=00:00:00.89 bitrate= 49.8kbits/s
frame= 89 fps= 88 q=7.0 size= 8kB time=00:00:01.42 bitrate= 44.7kbits/s
frame= 120 fps= 79 q=7.0 size= 10kB time=00:00:01.91 bitrate= 43.5kbits/s
frame= 150 fps= 74 q=6.0 size= 13kB time=00:00:02.43 bitrate= 44.7kbits/s
frame= 180 fps= 71 q=7.0 size= 16kB time=00:00:02.94 bitrate= 43.5kbits/s
frame= 210 fps= 69 q=7.0 size= 18kB time=00:00:03.45 bitrate= 42.5kbits/s
frame= 240 fps= 68 q=6.0 size= 20kB time=00:00:03.94 bitrate= 42.1kbits/s
frame= 271 fps= 67 q=6.0 size= 23kB time=00:00:04.43 bitrate= 43.3kbits/s
frame= 301 fps= 66 q=6.0 size= 26kB time=00:00:04.94 bitrate= 42.7kbits/s
frame= 331 fps= 66 q=7.0 size= 28kB time=00:00:05.46 bitrate= 42.2kbits/s
frame= 362 fps= 65 q=7.0 size= 31kB time=00:00:05.97 bitrate= 41.9kbits/s
frame= 392 fps= 65 q=7.0 size= 34kB time=00:00:06.46 bitrate= 42.6kbits/s
frame= 422 fps= 64 q=7.0 size= 36kB time=00:00:06.97 bitrate= 42.3kbits/s
frame= 452 fps= 64 q=7.0 size= 38kB time=00:00:07.48 bitrate= 41.9kbits/s
frame= 482 fps= 64 q=7.0 size= 41kB time=00:00:07.97 bitrate= 41.7kbits/s
frame= 512 fps= 63 q=7.0 size= 44kB time=00:00:08.49 bitrate= 42.2kbits/s
frame= 542 fps= 63 q=7.0 size= 46kB time=00:00:08.98 bitrate= 42.0kbits/s
frame= 573 fps= 63 q=6.0 size= 48kB time=00:00:09.49 bitrate= 41.8kbits/s
frame= 603 fps= 63 q=7.0 size= 51kB time=00:00:09.98 bitrate= 41.7kbits/s
frame= 634 fps= 63 q=7.0 size= 54kB time=00:00:10.49 bitrate= 42.1kbits/s
frame= 664 fps= 63 q=7.0 size= 56kB time=00:00:10.98 bitrate= 41.9kbits/s
frame= 694 fps= 63 q=7.0 size= 59kB time=00:00:11.49 bitrate= 41.7kbits/s
frame= 724 fps= 62 q=7.0 size= 61kB time=00:00:12.01 bitrate= 41.6kbits/s
frame= 755 fps= 62 q=7.0 size= 64kB time=00:00:12.50 bitrate= 42.0kbits/s
frame= 785 fps= 62 q=7.0 size= 66kB time=00:00:13.01 bitrate= 41.8kbits/s
frame= 815 fps= 62 q=6.0 size= 69kB time=00:00:13.52 bitrate= 41.6kbits/s
frame= 846 fps= 62 q=7.0 size= 71kB time=00:00:14.01 bitrate= 41.6kbits/s
frame= 876 fps= 62 q=7.0 size= 74kB time=00:00:14.52 bitrate= 41.9kbits/s
frame= 906 fps= 62 q=7.0 size= 77kB time=00:00:15.03 bitrate= 41.7kbits/s
***************** List cut because "Maximum number of characters in each post" ********************
[dshow @ 027581c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (65% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 027581c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (68% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 027581c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (77% of size: 128000000 [rtbufsize parameter])! frame dropped!
