On "Fullscreen">"Display 1" I'm unable to select anything other than "Output" (The dropdown allows selection, but the output does not change when applied) ---Issue is also present when attempted to change from Settings>Output (Same) ---Issue is also present when attempted via a Shortcut/Web (Same) ---Issue is present in a preset, as well as when no preset has been loaded  2021-02-03 20_02_00-Greenshot.png (166kb) downloaded 5 time(s).Also, I'd love to be able to select a "Mix" to output rather than the corresponding Input, but I suppose that's a feature request for down the road. I'm being asked to support both in-person and streaming, so being able to support 2 discreet outputs is a large breaking issue in my workflow.
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
This by design and has not changed in vMix 24. You must have Output selected in either Output 1 or Fullscreen 1, otherwise vMix has nowhere to process the main mix!. So it should be straightforward to re-arrange the outputs to what you need.
