Hi
I have a countdown timer I use in a fitness class. It counts down 30 to 0 and then repeats for then entire class. (HIIT STYLE CLASS) I’d like it to beep 3 times for last 3 seconds so clients know when to change.
I’d appreciate any help in achieving this....
Many thanks 🙏🏼
Joined: 12/27/2012(UTC) Posts: 5,492  Location: Belgium Thanks: 314 times Was thanked: 1019 time(s) in 837 post(s)
Script that checks the countdown time from the API XML and play a beep sound, could be an input , execute a external sound file or even a windows sound or a countdown that is 3 seconds shorter and trigger to play an input (3 second audio file ) that in turn trigger to repeat the process ( restart the countdown)
Have to wonder though why vMix has to do that ;-)
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Or a simple trigger "OnCountDownCompleted" play sound file.
Joined: 5/14/2013(UTC) Posts: 151  Location: uk Thanks: 2 times Was thanked: 27 time(s) in 23 post(s)
Use your choice of audio editing software and create a 30second audio file that is silent with the 3 beeps at the end , play this with your countdown , simple
