Medientechnik06
#1 Posted : Monday, February 1, 2021 9:26:41 PM(UTC)
Medientechnik06
Germany
Dear vMix Team,
up to now we used HD Version and worked with the templates.
Now our university, together with an media agency, is developing a new Video-CI.
We would get things like lower thirds and other Stuff as Adobe Illustrator files.
Is it possible to use those animations directly in GT designer 4k Version?
Kind regards
Jens
mjgraves
#2 Posted : Tuesday, February 2, 2021 4:42:58 AM(UTC)
mjgraves
Don't think so. Animations must be imported as rendered video files.
Medientechnik06
#3 Posted : Tuesday, February 2, 2021 6:23:29 AM(UTC)
Medientechnik06
Germany
So in gt designer pro i can Import those as video with Alpha channel, put my text animations over it and can take the whole thing as a title Object?
#4 Posted : Tuesday, February 2, 2021 6:51:41 AM(UTC)
No. you can use image sequences and i believe gifs too but not sure
Medientechnik06
#5 Posted : Tuesday, February 2, 2021 10:01:33 AM(UTC)
Medientechnik06
Germany
Boah, that would really suck. So how would we meet an university-wide Corporate Identitiy created by an external agency without building everything again at our own?
Babbit
#6 Posted : Tuesday, February 2, 2021 5:09:00 PM(UTC)
Babbit
Was thanked: 26 time(s) in 20 post(s)
You're going to have to do that to an extent with any character generator system. The Adobe ecosystem and live broadcast systems are very different things.
My art director comes up with cool things in After Effects to demo. It doesn't automatically mean it's practical in a live broadcast setting (in this example, he flunked with the notion of headroom), nevermind the system it has to go into (that being a really expensive Chyron).
At a bare minimum, you'll have to build the text boxes in GT. It's really not a realistic expectation to think things like that export and import seamlessly.
As mentioned, utilizing image sequences is your best best for bringing in elements. It is a very reasonable and common way of doing things. There's even a preset in Adobe Media encoder for PNG sequences, which by the way, is also useful for stinger transitions.
vMix posted a tutorial on this very topic:
vMix GT Image Sequence Tutorial
This is not an unheard of challenge. I will caution, however, that you might be in for a bit of a headache if the agency isn't doing things with broadcasting in mind. Print and web are very different beasts and are prone to not translating well.
#7 Posted : Tuesday, February 2, 2021 5:50:44 PM(UTC)
just convert the video to a image sequence and slap your texts etc over it
or be creative and work with layers :-)
