Is there any way to connect iPhone through USB
Hello dear creators and users of vMix!
I used OBS for several months with several cameras and iPhones through USB (not wifi) (through plugin) whithout any problem. Some days ago I found vMix and saw it much more convenient than OBS - VIDEO AND SOUND control made in much more better way.
I connected iPhone through LARIX+WIFI - it works - BUT with latence... the SOUND is also ASYNCHRONOUS.
Ofcource I can add a delay for ext. mic BUT if I have many camerar - I should do delay for every camera...
Also WiFi is not so stable as USB and not so fast as I know.
Thas why I ask:
Is there any way to connect iPhone\Android through USB
THANKS YOU VERY MUCH
May God bless you all!
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
You can do NDI with Epocam or NDIHX Camera apps over WIFI.
Quality will depend on your WIFI hardware and how busy the spectrum is.
We use all Ubiqiti hardware and it works perfectly.
Otherwise, Lightning>HDMI>HDMI Capture box>USB
