Hi! I´m tying to use the following code within Google Script to execute a fade function in Google sheets on a different computer than where vMix is installed. function Fade() { var res = UrlFetchApp.fetch('http://10.0.0.54:8088/api/?Function=Fade&Duration=8000');
But Google Sheets returs the following error: Exception: Bad request: http://10.0.0.54:8088/api/?Function=Fade&Duration=8000When I open the url: http://10.0.0.54:8088/api/?Function=Fade&Duration=8000 in Chrome browser the function executes correctly in vMix. Is this problem caused since the command comes from inside Google script or is my script wrong? Any help on this would be appreciate :-) Kim
