Feature Request: Add Shortcut verb to HTTP WEB API / script
Especially now that we have dynamic script capabilities it would be very nice to be able to execute a shortcut from a script. For example, if I inspect the standard web controller web page source code there is a ?shortcut='xxxx' (where xxxx is a GUID for the shortcut). In script it would be great to be able to do this: Script: Quote:shortcut=14a25f2f-edfb-4c56-904b-755dc980d3db ...but "Name 'shortcut' is not declared". Could "shortcut" be added as a valid script command? Note that this already works in the HTTP Web API (of course): Quote:http://127.0.0.1:8088/?shortcut=14a25f2f-edfb-4c56-904b-755dc980d3db
Have you tried with a httprequest from within the script ? (works btw) or Why not directly use the same functions in a script that would be in a shortcut ?
BTW there is a feature request section in this forum !
