Hardware Compatibility
G14 Zephyrus dedicated GPU usage problem
Joined: 2/25/2020(UTC) Posts: 18  Thanks: 4 times Was thanked: 4 time(s) in 3 post(s)
Hi, I just wanted to let this out as there are a lot of good laptops are coming out from Asus. When I first had this laptop with vMix it was able to detect and use GPU no problem. However with recent update to whatever(Window, Geforce app, or laptop firmware), it kept failed to recognize my GPU. Yes it has been answered a thousand times, but changing thing on Nvidia control panel didn't work as shown on this link. I found that you will actually have to go to windows setting to set vMix to use dedicated graphics card. 1. Right click your empty desktop screen 2. Open Display setting 3. Scroll bottom to find blue graphic settings 4. at the bottom click arrow and make sure "Desktop app" 5. Click Browse 6. Select vMix from this pathway (C:\Program Files (x86)\vMix\vMix64) 7. Select graphic to be high performance. This will override setting that was implemented with the patch. Let me know how this works our for you!
