Chumbaz
#1 Posted : Friday, January 22, 2021 6:26:07 PM(UTC)
Chumbaz
Italy
Here is my config:
- An intel based with nVidia 1080ti card running last vMix 23.0.0.67
- A mini pc intel based with intel graphic card
If i launch NDI Screen Capture on the minipc it is seen perfectly
If I launch NDI|HX Screen Capture no way (i can't see the device not the screen, it is as it is not connected to the network)
If I launch NDI|HX Creeen Capture and the Test Pattern it works perfectly
I have tested using the studio monitor too, same result
i am breaking my head since days, tested and resolution and rates possible in HX no way
Does somebody have an idea?
Thank you so very much
Follo
#2 Posted : Monday, January 25, 2021 6:40:31 PM(UTC)
Follo
Germany
Was thanked: 16 time(s) in 10 post(s)
Originally Posted by: Chumbaz Go to Quoted Post
Here is my config:
just to be sure, NDI Screen Capture HX is only working with a dedicated GPU from NVIDIA (a seperate Addon Card, no integrated GPU).
So it should work from your vMix PC to your mini PC (without running vMix [use screen capture HX], because vMix is using NDI without HX for outputs).
From your Mini PC to your vMix PC only Screen Capture should work. HX will not work, because you have an Intel embedded GPU.
Best regards
Chumbaz
#3 Posted : Monday, January 25, 2021 7:05:32 PM(UTC)
Chumbaz
Italy
Here is my config:
Best regards
OF COURSE
sometime most evident things are the ones you forget first
very kind of you, ciao and "grazie mille" (italian for "thank you so very much)
