Harpert
#1 Posted : Saturday, January 23, 2021 3:49:41 AM(UTC)
Harpert
Netherlands
We use multiple commands under ONE button in for example X-Touch.
If you press a button, more then one shortcut is executed.
for example:
- Solo ON (for Input X)
- BusA Audio off (for that input)
- Master off (for that input)
- Volume 0n level 80 (for that input)
If you click that button on the Midi device, all of the commands (shortcuts) are executed.
Each of these commands also (can) appear in the Web Interface.
The issue is that I would like them ALL to execute simultaniously
Is there a possibility to combine multiple (midi) shortcuts in ONE web controller button?
Thanks, Harpert
vjmandala
#2 Posted : Wednesday, November 27, 2024 8:57:57 AM(UTC)
vjmandala
I agree, this is a good practical question. Or at least stack several Functions within the shortcut itself so there is only 1 shortcut running several functions, that way it would appear as one buttn in web controller.
Guest (4)
