kross
#1 Posted : Tuesday, January 19, 2021 9:56:57 AM(UTC)
kross
Was thanked: 44 time(s) in 43 post(s)
Before you say "stop being so cheap, just buy an NVIDIA graphics card", I have a good reason for this.
I use small form factor builds. I use AMD APUs (integrated graphics). I use mini ITX motherboards with only a single expansion slot. I put a 4-port capture card in that slot, not a graphics card. So I can't just put an NVIDIA card in there.
The AMD APU has way more horsepower than any Intel integrated graphics. More than enough to run a live stream with a lot of inputs. It supports multiple encoding streams.
If vMix would support AMD GPU encoding for streaming, that would take a load off of the CPU, allowing for more inputs, more cameras, more instant replays on my small form factor build.
OBS supports AMD encoding for streaming, and local recording. vMix only supports it for local recording. Please add support for streaming encoding as well. Pretty please. :)
sherifwassef
#2 Posted : Friday, January 29, 2021 6:04:50 PM(UTC)
sherifwassef
Egypt
Though not documented, it is already Supported. MP4 h.264.
Windows 10 + Rx470 + Latest AMD Driver.
But on an old APU it might not.
