avkills
#1 Posted : Friday, January 15, 2021 2:17:41 AM(UTC)
avkills
Has anyone noticed if you push multiple streamdeck buttons, for instance if you have several push to talk audio bus buttons for your mic, and then push another button that sometimes other functions trigger that you did not want to?
And part 2, why does the ActiveInput function not signal to vMix that a transition has occurred? This makes it impossible to use a stream deck as a preview/program similar to a real broadcast switcher. Any triggers programmed into inputs do not fire if you make that input the "Active" input. I guess one could just write scripts but what a pain. (or am I missing a function that does what I want, put a input to program (output1) and do whatever triggers have been added to said input)
Also it would be nice if vMix could send return info to the StreamDeck so you could actually do change-states for toggle buttons. Also multiple actions would be nice as well.
dmwkr
#2 Posted : Friday, January 15, 2021 1:44:02 PM(UTC)
dmwkr
1) No, haven't experienced that.
2) Cut or Cutdirect?
3) Have you already looked at Activators in vMix? Also, you can assign multiple shortcuts to one button in vMix.
Vince Beck
#3 Posted : Saturday, January 16, 2021 4:23:02 AM(UTC)
Vince Beck
Sound to me like you have one shortcut doing 2 things. Double check your assignment.
As dmwkr said, using activators (https://www.youtube.com/watch?v=oPG6eq0ZiGg), you can turn the Stream Deck into a full fledged mixer, with preview color and program color that change automatically based on preview/program, audio on/off, etc.
You can set a shortcut to do multiple actions as well.
avkills
#4 Posted : Sunday, January 17, 2021 2:24:23 PM(UTC)
avkills
Thank you for the tips. I was not using Cut or Cut Direct, so I will look into those functions. Activators sound interesting.
(Vince I watched the youTube you linked to, think I can definitely get to the right path now, thank you sir!)
Vince Beck
#5 Posted : Monday, January 18, 2021 7:30:37 AM(UTC)
Vince Beck
Awesome, let us know if you run into more issues.
avkills
#6 Posted : Monday, January 18, 2021 1:39:55 PM(UTC)
avkills
I neat feature for the Activators would be being able to use custom background images to send to the StreamDeck (or any supported device), and/or being able to generate the exact color you wanted. It is cool as is though.
