Using Audio Beds with Triggers
Would anyone be able to tell me what the Function is to fade out background music when I transition out of a shot.
I'm using "Set Volume Fade" choosing my background music input and then setting any fade value and my background music continues to play away.
Clearly I'm doing something wrong!
Many thanks,
Paul
I'm clearly not using the Set Volume Fade correctly as Audio Off works but is abrupt. Should Set Volume Fade, fade our the music based on the millisecond value? Thanks!
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
There are actually two values you have to put into the value field:
Value = Volume 0-100,Milliseconds
So e.g. 0,2000 for a fadeout over 2 seconds.
