vMix Call
External Mix Minus
Joined: 7/25/2020(UTC) Posts: 6  Location: San Francisco Thanks: 1 times
How would you go about sending up 4 individual callers ISO out of Vmix to an audio console, mix them and reinsert them into Vmix with other content from the external audio console? Additionally having a producer mic (located on external audio console) talk to Vmix callers individually. Neither NDI or Dante are an option. 4 audio inputs and outputs are available thru an interface.
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
A problem ight be, that there are not enough audio busses to handle all that. Because to enable your producer to talk to the callers individually you need already 4 audio busses. e.g. call 1 Bus D, call 2 Bus E aso (at least in my daily routine its like that)
then there are only left Bus A,B,C so you could only send three calls individually to the mixing desk.
in how far you could use the Master Bus as an additional Bus is to test!
Also feedbacks might occur, when you send a caller back to its own audio bus...
So in my opinion the tryout would be use M-C as send and D-G as return and see what the feedbacks are producing :-)
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Output the callers individually to Bus D, E, F, G through your interface to your console.
Three inputs in vMix: - Master mix of your console, route it to M bus in vMix - Master mix of your console minus the callers, route it to bus A - Producer mic, route it to bus B
In vMix, Bus A is the return bus for your callers. Route all individual calls directly to this bus.
Create shortcuts for talkback that temporarily return bus B to an individual caller.
It would be nice if vMix can consider DirectOut and DirectIn for Audio ASIO for vmixcall. Those who use M32 or bigger digital board should have enough ASIO and Channels.
Joined: 4/23/2017(UTC) Posts: 1,476  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
To get a sense of what you can do take a look at this video
vMix Call
External Mix Minus
