wkrasley
#1 Posted : Friday, March 21, 2014 2:53:02 PM(UTC)
wkrasley
I do a live broadcast where a host sits on a couch facing the guest on another couch. I want to put different scenes behind each couch using 2 cameras (inputs) and green screen. How do I make the selected image static for each camera? I can put the same image behind both but I want to make it look like different windows behind each couch.
wkrasley
#2 Posted : Monday, March 24, 2014 10:33:06 AM(UTC)
wkrasley
How do you set it up to switch between them? When I switch cameras, the image stays the same.
wkrasley
#3 Posted : Tuesday, March 25, 2014 9:43:59 AM(UTC)
wkrasley
OK< thanks. I knew there was a way, but could not figure it out.
#4 Posted : Tuesday, March 25, 2014 9:52:53 AM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
You can use MultiView to compose new inputs containing multiple sources layered together, including chroma key.
See http://www.vmix.com.au/h...utSettingsMultiView.html
And http://www.vmix.com.au/k...chroma-key-setup-in-vmix
wkrasley
#5 Posted : Saturday, March 29, 2014 7:39:08 AM(UTC)
wkrasley
Thank you Martin, that's exactly what I needed. I got it working now and works great!
